Saltar al contenido principal
Amazon Fire HD 10 Rear Facing Camera Replacement
Qué necesitas
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: paso 1, imagen 1 de 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: paso 1, imagen 2 de 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: paso 1, imagen 3 de 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: paso 2, imagen 1 de 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: paso 3, imagen 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: paso 3, imagen 2 de 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: paso 5, imagen 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: paso 5, imagen 2 de 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: paso 6, imagen 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: paso 6, imagen 2 de 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: paso 7, imagen 1 de 2 Amazon Fire HD 10 Rear Facing Camera Replacement: paso 7, imagen 2 de 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
Conclusión
2 personas más completaron esta guía.
Jaie Hillery
Miembro Desde 10/07/14
1,718 Reputación
10 Guías creadas
Equipo
USF Tampa, Team 16-6, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 896
