Saltar al contenido principal
Amazon Fire HD 10 Front Facing Camera Replacement
Qué necesitas
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: paso 1, imagen 1 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: paso 1, imagen 2 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: paso 1, imagen 3 de 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Front Facing Camera Replacement: paso 2, imagen 1 de 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Front Facing Camera Replacement: paso 3, imagen 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: paso 3, imagen 2 de 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 1 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 2 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 3 de 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  6. Amazon Fire HD 10 Front Facing Camera Replacement: paso 6, imagen 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: paso 6, imagen 2 de 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  7. Amazon Fire HD 10 Front Facing Camera Replacement: paso 7, imagen 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: paso 7, imagen 2 de 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  8. Amazon Fire HD 10 Front Facing Camera Replacement: paso 8, imagen 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: paso 8, imagen 2 de 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jaie Hillery
Miembro Desde 10/07/14
1,757 Reputación
10 Guías creadas
Equipo
USF Tampa, Team 16-6, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
Miembros de 3
22 Guías creadas
1Guía Comentario
Can this camera module be upgraded with a better version?
Jimmy Kee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,205
