Saltar al contenido principal
Amazon Fire Game Controller Outer Shell Replacement
Qué necesitas
  1. Amazon Fire Game Controller Outer Shell Replacement, Motherboard: paso 1, imagen 1 de 1
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
  2. Amazon Fire Game Controller Outer Shell Replacement: paso 2, imagen 1 de 1
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
  3. Amazon Fire Game Controller Outer Shell Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
  4. Amazon Fire Game Controller Outer Shell Replacement: paso 4, imagen 1 de 1
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
  5. Amazon Fire Game Controller Outer Shell Replacement: paso 5, imagen 1 de 1
    • Lift the motherboard out of the controller casing.
  6. Amazon Fire Game Controller Outer Shell Replacement, Outer Shell: paso 6, imagen 1 de 1
    • Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
  7. Amazon Fire Game Controller Outer Shell Replacement: paso 7, imagen 1 de 1
    • Use a JIS #0 screwdriver to unscrew the 5 mm screws from the LED indicator assembly.
  8. Amazon Fire Game Controller Outer Shell Replacement: paso 8, imagen 1 de 2 Amazon Fire Game Controller Outer Shell Replacement: paso 8, imagen 2 de 2
    • Slide out the triggers and bumpers.
Conclusión
Equipo
IUPUI, Team S4-G4, Wilson Summer 2019 Miembro de IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 613
