Saltar al contenido principal
Amazon Echo Woofer Replacement
Qué necesitas
  1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: paso 1, imagen 1 de 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Woofer Replacement: paso 2, imagen 1 de 3 Amazon Echo Woofer Replacement: paso 2, imagen 2 de 3 Amazon Echo Woofer Replacement: paso 2, imagen 3 de 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Woofer Replacement: paso 3, imagen 1 de 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Woofer Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Woofer Replacement: paso 5, imagen 1 de 2 Amazon Echo Woofer Replacement: paso 5, imagen 2 de 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Woofer Replacement: paso 6, imagen 1 de 3 Amazon Echo Woofer Replacement: paso 6, imagen 2 de 3 Amazon Echo Woofer Replacement: paso 6, imagen 3 de 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Woofer Replacement, Tweeter Assembly: paso 7, imagen 1 de 2 Amazon Echo Woofer Replacement, Tweeter Assembly: paso 7, imagen 2 de 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Woofer Replacement: paso 8, imagen 1 de 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Woofer Replacement: paso 9, imagen 1 de 3 Amazon Echo Woofer Replacement: paso 9, imagen 2 de 3 Amazon Echo Woofer Replacement: paso 9, imagen 3 de 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
  10. Amazon Echo Woofer Replacement, Woofer: paso 10, imagen 1 de 1
    • Lift the woofer out of the Echo.
Conclusión
Una persona más ha completado esta guía.
Alexander Albert
Miembro Desde 02/04/16
1,145 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-3, Wollert Spring 2016 Miembro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
Miembros de 4
12 Guías creadas
3 comentarios
Where can you buy a replacement woofer?
adam mierzwa - Contestar
My exact question.
Marty Koenig -
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 7,968
