Saltar al contenido principal
Amazon Echo Studio Motherboard Replacement
Qué necesitas
  1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: paso 1, imagen 1 de 3 Amazon Echo Studio Motherboard Replacement, Power Supply Board: paso 1, imagen 2 de 3 Amazon Echo Studio Motherboard Replacement, Power Supply Board: paso 1, imagen 3 de 3
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Motherboard Replacement: paso 2, imagen 1 de 3 Amazon Echo Studio Motherboard Replacement: paso 2, imagen 2 de 3 Amazon Echo Studio Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Motherboard Replacement: paso 3, imagen 1 de 3 Amazon Echo Studio Motherboard Replacement: paso 3, imagen 2 de 3 Amazon Echo Studio Motherboard Replacement: paso 3, imagen 3 de 3
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Motherboard Replacement: paso 4, imagen 1 de 2 Amazon Echo Studio Motherboard Replacement: paso 4, imagen 2 de 2
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
  5. Amazon Echo Studio Motherboard Replacement, Subwoofer: paso 5, imagen 1 de 1
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
  6. Amazon Echo Studio Motherboard Replacement: paso 6, imagen 1 de 3 Amazon Echo Studio Motherboard Replacement: paso 6, imagen 2 de 3 Amazon Echo Studio Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
  7. Amazon Echo Studio Motherboard Replacement: paso 7, imagen 1 de 2 Amazon Echo Studio Motherboard Replacement: paso 7, imagen 2 de 2
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
  8. Amazon Echo Studio Motherboard Replacement, Motherboard: paso 8, imagen 1 de 2 Amazon Echo Studio Motherboard Replacement, Motherboard: paso 8, imagen 2 de 2
    • Remove the thirteen 9 mm Phillips #00 screws.
    • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
  9. Amazon Echo Studio Motherboard Replacement: paso 9, imagen 1 de 1
    • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
    • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
  10. Amazon Echo Studio Motherboard Replacement: paso 10, imagen 1 de 3 Amazon Echo Studio Motherboard Replacement: paso 10, imagen 2 de 3 Amazon Echo Studio Motherboard Replacement: paso 10, imagen 3 de 3
    • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
  11. Amazon Echo Studio Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard from the device by pulling it out.
    • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
Conclusión
Colin Nicoll
Miembro Desde 10/26/22
109 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Miembro de UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Miembros
6 Guías creadas
5 comentarios
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - Contestar
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - Contestar
i also would like to know. mine stuck with cyan circle
Алексей - Contestar
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - Contestar
hi is there a place to buy this motherboard?
Bede Bede - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 56
Todo El Tiempo: 1,031
