Saltar al contenido principal
Amazon Echo Show Top Button Replacement
Qué necesitas
  1. Amazon Echo Show Top Button Replacement, Back Cover: paso 1, imagen 1 de 2 Amazon Echo Show Top Button Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using your hands, gently remove the taped-in rubber foot from device.
  2. Amazon Echo Show Top Button Replacement: paso 2, imagen 1 de 2 Amazon Echo Show Top Button Replacement: paso 2, imagen 2 de 2
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  3. Amazon Echo Show Top Button Replacement: paso 3, imagen 1 de 1
    • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
  4. Amazon Echo Show Top Button Replacement: paso 4, imagen 1 de 2 Amazon Echo Show Top Button Replacement: paso 4, imagen 2 de 2
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Repeat this step for the other speaker, and lay the front section flat with the facing down.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
  5. Amazon Echo Show Top Button Replacement, Top Buttons: paso 5, imagen 1 de 3 Amazon Echo Show Top Button Replacement, Top Buttons: paso 5, imagen 2 de 3 Amazon Echo Show Top Button Replacement, Top Buttons: paso 5, imagen 3 de 3
    • Locate the panel holding the buttons on the top of the device. Using the T5 Torx screw head, remove the eight screws to detach the panel holding the buttons in place.
    • Once the panel is removed, the three plastic buttons can be easily accessed and removed for replacement/fixing.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take care to not accidentally switch your top buttons' alignment.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 391
