Saltar al contenido principal
Amazon Echo Show 5-Megapixel Camera Replacement
Qué necesitas
  1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: paso 1, imagen 1 de 2 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: paso 1, imagen 2 de 2
    • Use the plastic opening tool to gently lift the plastic protector from the screen.
  2. Amazon Echo Show 5-Megapixel Camera  Replacement: paso 2, imagen 1 de 2 Amazon Echo Show 5-Megapixel Camera  Replacement: paso 2, imagen 2 de 2
    • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
  3. Amazon Echo Show 5-Megapixel Camera  Replacement: paso 3, imagen 1 de 1
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  4. Amazon Echo Show 5-Megapixel Camera  Replacement: paso 4, imagen 1 de 3 Amazon Echo Show 5-Megapixel Camera  Replacement: paso 4, imagen 2 de 3 Amazon Echo Show 5-Megapixel Camera  Replacement: paso 4, imagen 3 de 3
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Lay the front section flat, with the screen down.
  5. Amazon Echo Show 5-Megapixel Camera  Replacement: paso 5, imagen 1 de 3 Amazon Echo Show 5-Megapixel Camera  Replacement: paso 5, imagen 2 de 3 Amazon Echo Show 5-Megapixel Camera  Replacement: paso 5, imagen 3 de 3
    • Remove two 1mm T5 Torx screws.
    • Once the screws have been removed, you can easily remove the camera from the device.
Conclusión
Un comentario
Can not reset amazon echo show model MW46WB tried everything any suggestions
Skippy Gessler - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 2,140
