Saltar al contenido principal
Amazon Echo Show 2nd Gen Sound foam Replacement
Qué necesitas
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: paso 1, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: paso 1, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: paso 1, imagen 3 de 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: paso 2, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement: paso 2, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound foam Replacement: paso 2, imagen 3 de 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,602
