Saltar al contenido principal
Amazon Echo Show 2nd Gen Sound Card Replacement
Qué necesitas
  1. Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: paso 1, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: paso 1, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound foam: paso 1, imagen 3 de 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound Card Replacement: paso 2, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement: paso 2, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement: paso 2, imagen 3 de 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
  3. Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: paso 3, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: paso 3, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement, Sound Card: paso 3, imagen 3 de 3
    • Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
    • Pull on the top until the case becomes fully dislodged.
  4. Amazon Echo Show 2nd Gen Sound Card Replacement: paso 4, imagen 1 de 2 Amazon Echo Show 2nd Gen Sound Card Replacement: paso 4, imagen 2 de 2
    • Pull out the two white plugs by firmly grasping them and pulling in a downward motion until they become disconnected.
  5. Amazon Echo Show 2nd Gen Sound Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the 4mm, red-marked screws with the TR6 screwdriver bit.
    • Detach the ribbon from the circuit board by grasping from the top of the ribbon and pulling away from the board.
  6. Amazon Echo Show 2nd Gen Sound Card Replacement: paso 6, imagen 1 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement: paso 6, imagen 2 de 3 Amazon Echo Show 2nd Gen Sound Card Replacement: paso 6, imagen 3 de 3
    • Unscrew the red-marked, 4mm screws with the J1 screwdriver bit.
    • Carefully slide the sound card up and out of the black casing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 372
