Saltar al contenido principal
Amazon Echo Motherboard Replacement
Qué necesitas
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: paso 1, imagen 1 de 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: paso 2, imagen 1 de 3 Amazon Echo Motherboard Replacement: paso 2, imagen 2 de 3 Amazon Echo Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: paso 3, imagen 1 de 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: paso 5, imagen 1 de 2 Amazon Echo Motherboard Replacement: paso 5, imagen 2 de 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: paso 6, imagen 1 de 3 Amazon Echo Motherboard Replacement: paso 6, imagen 2 de 3 Amazon Echo Motherboard Replacement: paso 6, imagen 3 de 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Amazon Echo Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: paso 8, imagen 1 de 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: paso 9, imagen 1 de 2 Amazon Echo Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: paso 10, imagen 1 de 3 Amazon Echo Motherboard Replacement: paso 10, imagen 2 de 3 Amazon Echo Motherboard Replacement: paso 10, imagen 3 de 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: paso 11, imagen 1 de 1
    • Lift the motherboard up from the Echo.
Conclusión
4 personas más completaron esta guía.
Alexander Albert
Miembro Desde 02/04/16
1,145 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-3, Wollert Spring 2016 Miembro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Miembros
12 Guías creadas
11 comentarios
Where can you get the mmotherboard
Glen Seay - Contestar
same question. where do i get replacement motherboard?
akn978s - Contestar
This is how to remove the motherboard not how to replace it....geez
adairt - Contestar
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Contestar
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 66
Todo El Tiempo: 14,785
