Saltar al contenido principal
Amazon Echo Dot 2nd Generation Speaker Replacement
Qué necesitas
  1. Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Speaker Replacement: paso 2, imagen 1 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement: paso 2, imagen 2 de 3 Amazon Echo Dot 2nd Generation Speaker Replacement: paso 2, imagen 3 de 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Amazon Echo Dot 2nd Generation Speaker Replacement: paso 3, imagen 1 de 1
    • Tap the base against the palm of your hand so that the black speaker component comes out
Conclusión
14 personas más completaron esta guía.
Alexis White
Miembro Desde 10/09/17
505 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Miembros
12 Guías creadas
3 comentarios
Where can one purchase the replacement speaker component?
ananomaus - Contestar
Can you inform us were to get replacement speaker please.
John Stead - Contestar
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
Meghan Craig - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 75
Todo El Tiempo: 13,176
