Saltar al contenido principal
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
Qué necesitas
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 2, imagen 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 2, imagen 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 2, imagen 3 de 3
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 3, imagen 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 3, imagen 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 3, imagen 3 de 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 4, imagen 1 de 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 5, imagen 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 5, imagen 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 5, imagen 3 de 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 6, imagen 1 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 6, imagen 2 de 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: paso 6, imagen 3 de 3
    • Remove the ribbon cable from the slot on the LED/speaker board
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Miembros
12 Guías creadas
5 comentarios
Where do you get the replacement cable from?
jonathan kabitzke - Contestar
Yes, where can one get replacement ribbon cables?
Armando Morreale - Contestar
Malcolm oakley - Contestar
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Contestar
no cable available, just waiting for donors
Ray Floyd Cabrera - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 2,495
