Saltar al contenido principal
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
Qué necesitas
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: paso 1, imagen 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: paso 1, imagen 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: paso 1, imagen 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 2, imagen 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 2, imagen 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 2, imagen 3 de 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 3, imagen 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 3, imagen 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 3, imagen 3 de 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 4, imagen 1 de 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 5, imagen 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 5, imagen 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 5, imagen 3 de 3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 6, imagen 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 6, imagen 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 6, imagen 3 de 3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: paso 7, imagen 1 de 1
    • Remove the LED/speaker board
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Miembros
12 Guías creadas
Un comentario
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 4,926
