Saltar al contenido principal
Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement
Qué necesitas
  1. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: paso 1, imagen 1 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: paso 1, imagen 2 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: paso 1, imagen 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 2, imagen 1 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 2, imagen 2 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 2, imagen 3 de 3
    • Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 3, imagen 1 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 3, imagen 2 de 3 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 3, imagen 3 de 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: paso 4, imagen 1 de 1
    • Remove the motherboard
Conclusión
8 personas más completaron esta guía.
Alexis White
Miembro Desde 10/09/17
577 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
Miembros de 3
12 Guías creadas
2Guía Comentarios
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
Ivy Bowman - Contestar
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
rayramirez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 49
Todo El Tiempo: 7,155
