Saltar al contenido principal
Amazon Echo 2nd Generation Speaker Replacement
Qué necesitas
  1. Amazon Echo 2nd Generation Speaker Replacement, AMP Board: paso 1, imagen 1 de 3 Amazon Echo 2nd Generation Speaker Replacement, AMP Board: paso 1, imagen 2 de 3 Amazon Echo 2nd Generation Speaker Replacement, AMP Board: paso 1, imagen 3 de 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation Speaker Replacement: paso 2, imagen 1 de 3 Amazon Echo 2nd Generation Speaker Replacement: paso 2, imagen 2 de 3 Amazon Echo 2nd Generation Speaker Replacement: paso 2, imagen 3 de 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation Speaker Replacement: paso 3, imagen 1 de 2 Amazon Echo 2nd Generation Speaker Replacement: paso 3, imagen 2 de 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  4. Amazon Echo 2nd Generation Speaker Replacement, Subwoofer (speaker): paso 4, imagen 1 de 2 Amazon Echo 2nd Generation Speaker Replacement, Subwoofer (speaker): paso 4, imagen 2 de 2
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
  5. Amazon Echo 2nd Generation Speaker Replacement: paso 5, imagen 1 de 2 Amazon Echo 2nd Generation Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
Conclusión
Una persona más ha completado esta guía.
Eric Inman
Miembro Desde 10/08/18
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G4, White Fall 2018 Miembro de Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 3,696
