Saltar al contenido principal
Amazon Echo 2nd Generation AMP Board Replacement
Qué necesitas
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: paso 1, imagen 1 de 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: paso 1, imagen 2 de 3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: paso 1, imagen 3 de 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation AMP Board Replacement: paso 2, imagen 1 de 3 Amazon Echo 2nd Generation AMP Board Replacement: paso 2, imagen 2 de 3 Amazon Echo 2nd Generation AMP Board Replacement: paso 2, imagen 3 de 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation AMP Board Replacement: paso 3, imagen 1 de 2 Amazon Echo 2nd Generation AMP Board Replacement: paso 3, imagen 2 de 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
Conclusión
Una persona más ha completado esta guía.
Eric Inman
Miembro Desde 10/08/18
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G4, White Fall 2018 Miembro de Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Miembros
5 Guías creadas
3 comentarios
Can anyone find a replacement board?
Tristan Parks - Contestar
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - Contestar
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 55
Todo El Tiempo: 3,650
