Saltar al contenido principal
Aluratek ADMPF310F Speakers Replacement
Qué necesitas
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: paso 1, imagen 1 de 3 Aluratek ADMPF310F Speakers Replacement, Speakers: paso 1, imagen 2 de 3 Aluratek ADMPF310F Speakers Replacement, Speakers: paso 1, imagen 3 de 3
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: paso 2, imagen 1 de 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: paso 3, imagen 1 de 2 Aluratek ADMPF310F Speakers Replacement: paso 3, imagen 2 de 2
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: paso 4, imagen 1 de 2 Aluratek ADMPF310F Speakers Replacement: paso 4, imagen 2 de 2
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: paso 5, imagen 1 de 1
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
Conclusión
Chris Belair
Miembro Desde 10/20/16
333 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 115
