Saltar al contenido principal
Aluratek ADMPF310F Replacing USB Port Replacement
Qué necesitas
  1. Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: paso 1, imagen 1 de 3 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: paso 1, imagen 2 de 3 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: paso 1, imagen 3 de 3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Replacing USB Port Replacement: paso 2, imagen 1 de 1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Replacing USB Port Replacement: paso 3, imagen 1 de 2 Aluratek ADMPF310F Replacing USB Port Replacement: paso 3, imagen 2 de 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Replacing USB Port Replacement: paso 4, imagen 1 de 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Replacing USB Port Replacement: paso 5, imagen 1 de 1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Replacing USB Port Replacement: paso 6, imagen 1 de 2 Aluratek ADMPF310F Replacing USB Port Replacement: paso 6, imagen 2 de 2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Replacing USB Port Replacement: paso 7, imagen 1 de 3 Aluratek ADMPF310F Replacing USB Port Replacement: paso 7, imagen 2 de 3 Aluratek ADMPF310F Replacing USB Port Replacement: paso 7, imagen 3 de 3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Replacing USB Port Replacement: paso 8, imagen 1 de 1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
  9. Aluratek ADMPF310F Replacing USB Port Replacement, USB Port: paso 9, imagen 1 de 1
    • On the back end of the mother board unsolder the USB port at the two points shown.
Conclusión
Pascal Alexis
Miembro Desde 11/05/15
427 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 141
