Introducción
In this guide you will learn how to remove and replace the remote sensor in your digital frame. Replacing the remote sensor fixes many common issues if your remote isn't working with your device. This guide also requires soldering for more on how to solder check the link here.
Qué necesitas
Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
Pull out the remote sensor from its holder with your hands.
Unsolder the remote sensor from the motherboard.
