Saltar al contenido principal
Aluratek ADMPF310F Remote Sensor Replacement
Qué necesitas
  1. Aluratek ADMPF310F Remote Sensor Replacement, Screen: paso 1, imagen 1 de 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: paso 1, imagen 2 de 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: paso 1, imagen 3 de 3
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Remote Sensor Replacement: paso 2, imagen 1 de 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Remote Sensor Replacement: paso 3, imagen 1 de 2 Aluratek ADMPF310F Remote Sensor Replacement: paso 3, imagen 2 de 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Remote Sensor Replacement: paso 4, imagen 1 de 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Remote Sensor Replacement, Remote Sensor: paso 5, imagen 1 de 1
    • Pull out the remote sensor from its holder with your hands.
    • Unsolder the remote sensor from the motherboard.
  6. Aluratek ADMPF310F Remote Sensor Replacement: paso 6, imagen 1 de 1
    • Resolder the the remote sensor back to the motherboard.
    • For more on how to solder check the link here.
Conclusión
Pascal Alexis
Miembro Desde 11/05/15
427 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 169
