Introducción
Remove and replace alternator on a Briggs and Stratton 5.5 horsepower lawnmower engine.
Qué necesitas
Push the metal tab closest to the black wire down. While pushing the tab down, pull the black wire out of the clip.
Using a 1/4 socket, remove the two bolts holding the alternator to the engine.
From the alternator side, gently pull the black wire out past the cylinder it is routed under on the engine.
2 personas más completaron esta guía.
