Introducción
The iPod Dock is the part of the speaker that the iPod connects to. Replacement of the iPod Dock requires removal of the batteries, the volume and power buttons, and the motherboard. Soldering skills are required; take a look at this soldering guide for extra help.
Qué necesitas
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
To remove the iPod Dock, unscrew the four 8mm screws located on the corners of the dock casing using the Phillips #1 screwdriver.
2 personas más completaron esta guía.
