Saltar al contenido principal
Altec Lansing inMotion iM9 Woofer Replacement
Qué necesitas
  1. Altec Lansing inMotion iM9 Woofer Replacement, Battery: paso 1, imagen 1 de 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Woofer Replacement: paso 2, imagen 1 de 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Woofer Replacement, Volume and Power Buttons: paso 3, imagen 1 de 2 Altec Lansing inMotion iM9 Woofer Replacement, Volume and Power Buttons: paso 3, imagen 2 de 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Woofer Replacement: paso 4, imagen 1 de 2 Altec Lansing inMotion iM9 Woofer Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Woofer Replacement: paso 5, imagen 1 de 2 Altec Lansing inMotion iM9 Woofer Replacement: paso 5, imagen 2 de 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
  6. Altec Lansing inMotion iM9 Woofer Replacement, Case Opening: paso 6, imagen 1 de 2 Altec Lansing inMotion iM9 Woofer Replacement, Case Opening: paso 6, imagen 2 de 2
    • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
    • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Remove the silver lining.
  7. Altec Lansing inMotion iM9 Woofer Replacement: paso 7, imagen 1 de 2 Altec Lansing inMotion iM9 Woofer Replacement: paso 7, imagen 2 de 2
    • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
    • Once loose, lift up the metal mesh.
  8. Altec Lansing inMotion iM9 Woofer Replacement: paso 8, imagen 1 de 1
    • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the 7mm screw with the Phillips #1 Screwdriver.
  9. Altec Lansing inMotion iM9 Woofer Replacement: paso 9, imagen 1 de 1
    • Carefully separate the front and back case plates at a corner of the speaker.
    • Lots of cables are still connected, so be very gentle when separating case plates.
  10. Altec Lansing inMotion iM9 Woofer Replacement: paso 10, imagen 1 de 1
    • Guide the white button cables through the hole on the top of speaker case.
  11. Altec Lansing inMotion iM9 Woofer Replacement: paso 11, imagen 1 de 1
    • Use your fingers to peel the glue off of the red and black cables.
  12. Altec Lansing inMotion iM9 Woofer Replacement: paso 12, imagen 1 de 1
    • Careful not to touch the green capacitors or you might shock yourself.
  13. Altec Lansing inMotion iM9 Woofer Replacement, Woofer: paso 13, imagen 1 de 1
    • Take out the woofer from the front of the speaker with cable attached.
  14. Altec Lansing inMotion iM9 Woofer Replacement: paso 14, imagen 1 de 1
    • Desolder the cable from the woofer.
Conclusión
Una persona más ha completado esta guía.
Johnson Zhou
Miembro Desde 02/02/15
240 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-33, Amido Winter 2015 Miembro de Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,080
