Saltar al contenido principal
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
Qué necesitas
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: paso 1, imagen 1 de 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: paso 2, imagen 1 de 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: paso 3, imagen 1 de 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: paso 3, imagen 2 de 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: paso 4, imagen 1 de 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: paso 5, imagen 1 de 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: paso 5, imagen 2 de 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
Conclusión
Ben Toland
Miembro Desde 02/01/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-33, Amido Winter 2015 Miembro de Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
Miembros de 4
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,614
