Introducción
The tweeter is the component that outputs the higher pitches of music. Replacing the tweeter requires the removal of the batteries and the volume and power buttons. Also, this guide requires soldering skills: for help with soldering check out the soldering guide.
Qué necesitas
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Remove the speaker cables by desoldering the two solder joints on opposite sides of the tweeter.
