Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If you need access to any of the internal components of your Altec Lansing VersA Smart speaker to replace components, start with this basic removal guide. This guide is a prerequisite to all other repair guides. In this guide, you will remove all external panels and coverings to expose the components within.
  1. Remove external rubber cover.
    • Remove external rubber cover.
  2. Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom. Use a lever motion, push the tool down, lifting the speaker face.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side. Remove the seven 14mm screws using the Phillips #1 screwdriver.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  5. Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
Linea de Meta
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 93
