Saltar al contenido principal
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Qué necesitas
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: paso 1, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: paso 1, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: paso 1, imagen 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 2, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 2, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 2, imagen 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 3, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 3, imagen 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 4, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 4, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 5, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 5, imagen 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 6, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 6, imagen 2 de 2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 8, imagen 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 9, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 9, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 9, imagen 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: paso 10, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: paso 10, imagen 2 de 2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 11, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 11, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 11, imagen 3 de 3
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 12, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: paso 12, imagen 2 de 2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Conclusión
Una persona más ha completado esta guía.
Stephen Albrecht
Miembro Desde 02/14/18
1,029 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S3-G2, Nance Spring 2018 Miembro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Miembros
4 Guías creadas
2 comentarios
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Contestar
Where can I get this speaker parts?
T Rex movies - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 32
Todo El Tiempo: 4,021
