Saltar al contenido principal
Altec Lansing Mini Lifejacket 2 Motherboard Replacement
Qué necesitas
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: paso 1, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: paso 1, imagen 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 2, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 2, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 2, imagen 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 3, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 4, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 4, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 5, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 5, imagen 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 6, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 8, imagen 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 9, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 9, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 9, imagen 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: paso 10, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: paso 10, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: paso 10, imagen 3 de 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Unplug the remaining four wire harnesses attached to the circuit board
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 12, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 13, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 13, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the motherboard.
Conclusión
2 personas más completaron esta guía.
Stephen Albrecht
Miembro Desde 02/14/18
1,029 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S3-G2, Nance Spring 2018 Miembro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Miembros
4 Guías creadas
6 comentarios
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Contestar
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Contestar
need back panel replacement
rahul pande - Contestar
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Contestar
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 5,431
