Saltar al contenido principal
Altec Lansing Mini Lifejacket 2 Battery Replacement
Qué necesitas
  1. Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: paso 1, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: paso 1, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: paso 1, imagen 3 de 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 2, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 2, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 2, imagen 3 de 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 3, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 3, imagen 2 de 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 4, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 4, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 4, imagen 3 de 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 5, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 5, imagen 2 de 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 6, imagen 1 de 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 6, imagen 2 de 2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 7, imagen 1 de 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 8, imagen 1 de 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 9, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 9, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: paso 9, imagen 3 de 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: paso 10, imagen 1 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: paso 10, imagen 2 de 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: paso 10, imagen 3 de 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
Conclusión
8 personas más completaron esta guía.
Stephen Albrecht
Miembro Desde 02/14/18
1,029 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S3-G2, Nance Spring 2018 Miembro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Miembros
4 Guías creadas
10 comentarios
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - Contestar
Search for MCR18650 battery. They are available.
F Hickisch - Contestar
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
rudy.ch.garcia - Contestar
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
Edgar Corral (Tramarius) - Contestar
For the mini life jacket 3 can you send what link you had for the battery?
Malena Reyes -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 37
Ultimos 30 días: 197
Todo El Tiempo: 21,321
