Saltar al contenido principal
Altec Lansing BoomJacket Speaker Replacement
Qué necesitas
  1. Altec Lansing BoomJacket Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Speaker Replacement: paso 4, imagen 1 de 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Speaker Replacement: paso 5, imagen 1 de 2 Altec Lansing BoomJacket Speaker Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Speaker Replacement: paso 6, imagen 1 de 1
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Altec Lansing BoomJacket Speaker Replacement: paso 7, imagen 1 de 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
Conclusión
2 comentarios
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Contestar
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 754
