Saltar al contenido principal
Altec Lansing BoomJacket Bluetooth Board Replacement
Qué necesitas
  1. Altec Lansing BoomJacket Bluetooth Board Replacement, Case Removal: paso 1, imagen 1 de 1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 2, imagen 1 de 1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 3, imagen 1 de 1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 4, imagen 1 de 1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 5, imagen 1 de 2 Altec Lansing BoomJacket Bluetooth Board Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 6, imagen 1 de 1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 7, imagen 1 de 1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Bluetooth Board Replacement, Bluetooth Board: paso 8, imagen 1 de 1
    • Now that the case is open look for the small green (NFC) chip on the inside of the case next to the motherboard.
  9. Altec Lansing BoomJacket Bluetooth Board Replacement: paso 9, imagen 1 de 1
    • Disconnect the Bluetooth (NFC) chip from the motherboard.
Conclusión
2 personas más completaron esta guía.
Un comentario
Is this a common issue with the Lifejacket 3? I was able to use my new BT speaker twice, since it was bought last week. The speaker hasn't been dropped, in or around water, outside, left on, damaged, or tampered with.
Kat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 25
Todo El Tiempo: 4,767
