Saltar al contenido principal
Altec Lansing BoomJacket 2 Speaker Replacement
Qué necesitas
  1. Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 2 de 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Speaker Replacement: paso 2, imagen 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: paso 2, imagen 2 de 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Speaker Replacement: paso 3, imagen 1 de 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Speaker Replacement: paso 4, imagen 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Speaker Replacement: paso 5, imagen 1 de 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Speaker Replacement: paso 6, imagen 1 de 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: paso 7, imagen 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: paso 7, imagen 2 de 2
    • Unscrew the four screws holding the speaker in place.
  8. Altec Lansing BoomJacket 2 Speaker Replacement: paso 8, imagen 1 de 2 Altec Lansing BoomJacket 2 Speaker Replacement: paso 8, imagen 2 de 2
    • Unscrew the two screws on the smaller speaker.
    • Pull the small speaker through the larger speaker hole.
Conclusión
Una persona más ha completado esta guía.
Zach Braaten
Miembro Desde 07/12/18
537 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 463
