Saltar al contenido principal
Altec Lansing BoomJacket 2 Motherboard Replacement
Qué necesitas
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 1 de 2 Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 2 de 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 2, imagen 1 de 2 Altec Lansing BoomJacket 2 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 3, imagen 1 de 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 4, imagen 1 de 2 Altec Lansing BoomJacket 2 Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: paso 7, imagen 1 de 1
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 8, imagen 1 de 1
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 10, imagen 1 de 1
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: paso 11, imagen 1 de 1
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
Conclusión
Una persona más ha completado esta guía.
Zach Braaten
Miembro Desde 07/12/18
537 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Miembros
4 Guías creadas
Un comentario
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 878
