Saltar al contenido principal
Altec Lansing BoomJacket 2 Battery Replacement
Qué necesitas
  1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 1 de 2 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: paso 1, imagen 2 de 2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Battery Replacement: paso 2, imagen 1 de 2 Altec Lansing BoomJacket 2 Battery Replacement: paso 2, imagen 2 de 2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Battery Replacement: paso 3, imagen 1 de 1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Battery Replacement: paso 4, imagen 1 de 2 Altec Lansing BoomJacket 2 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Battery Replacement: paso 5, imagen 1 de 1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Battery Replacement: paso 6, imagen 1 de 1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Battery Replacement, Battery: paso 7, imagen 1 de 1
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Battery Replacement: paso 8, imagen 1 de 1
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
Conclusión
2 personas más completaron esta guía.
Zach Braaten
Miembro Desde 07/12/18
537 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 1,548
