Saltar al contenido principal
Alpine Ski Wax Application
Qué necesitas
  1. Alpine Ski Wax Application, Alpine Ski Wax Application: paso 1, imagen 1 de 1
    • Attach heavy rubber bands around the brakes.
  2. Alpine Ski Wax Application: paso 2, imagen 1 de 1
    • Spray base cleaner along the bottom of the ski.
  3. Alpine Ski Wax Application: paso 3, imagen 1 de 1
    • Wipe the skis with a towel, removing dirt, excess wax, the base cleaner, and dust.
  4. Alpine Ski Wax Application: paso 4, imagen 1 de 1
    • Spread wax across the base of the ski with an edge to edge motion. While doing this hold the iron perpendicular to the base and press the wax into the iron.
    • Be careful when handling the hot iron and the hot wax.
  5. Alpine Ski Wax Application: paso 5, imagen 1 de 1
    • Melt the wax into the base using a tip to tail stroke with the iron.
    • Let the skis dry for at least 30 minutes once all the wax is melted.
  6. Alpine Ski Wax Application: paso 6, imagen 1 de 1
    • Scrape the excess wax off with the plastic scraper. Continue this process until there is no visible wax on the ski base.
  7. Alpine Ski Wax Application: paso 7, imagen 1 de 1
    • Scrape the excess wax off of the side of the ski.
  8. Alpine Ski Wax Application: paso 8, imagen 1 de 1
    • Wipe the fine wax dust from the ski base.
Linea de Meta
Evan Gornick
Miembro Desde 09/26/17
101 Reputación
1 Guía escrita
Equipo
8 comentarios
Very nice post! That's a great website I have visited, thank you for your essentials words run 3
Martin Tolley - Contestar
I read your article very detailed and easy to understand, I hope next time you will have more wonderful articles to share with the reader.
run 3
switch color - Contestar
thansks for the post
Arun nagar - Contestar
'''WYSIWYG Web Builder Crack''' has a unique and easy to use tools for both beginners and professional developers. Hence it is straightforward to use application.
Harry Oscar - Contestar
I really enjoy the blog article. Much thanks again. Want more.
Wondershare Filmora Scrn Crack
DxO PhotoLab Crack
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 392
