Saltar al contenido principal
Alpine MRV-M500 Circuit Board Replacement
Qué necesitas
  1. Alpine MRV-M500 Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: paso 1, imagen 2 de 3 Alpine MRV-M500 Circuit Board Replacement, Circuit Board: paso 1, imagen 3 de 3
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
  2. Alpine MRV-M500 Circuit Board Replacement: paso 2, imagen 1 de 2 Alpine MRV-M500 Circuit Board Replacement: paso 2, imagen 2 de 2
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  3. Alpine MRV-M500 Circuit Board Replacement: paso 3, imagen 1 de 1
    • Remove the circuit board from the case.
Conclusión
To reassemble your device, follow these instructions in reverse order using the replacement circuit board.
4 personas más completaron esta guía.
Eric Gaulke
Miembro Desde 09/17/18
623 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 2,054
