Saltar al contenido principal
AlphaSmart Pro Lithium Coin Battery Replacement
Qué necesitas
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: paso 1, imagen 1 de 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: paso 1, imagen 2 de 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: paso 1, imagen 3 de 3
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: paso 2, imagen 1 de 2 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: paso 2, imagen 2 de 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: paso 3, imagen 1 de 2 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: paso 3, imagen 2 de 2
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: paso 4, imagen 1 de 2 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: paso 4, imagen 2 de 2
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
Conclusión
Katy Beth Culp
Miembro Desde 10/13/14
1 Reputación
2 Guías creadas
Equipo
Clemson, Team 1-1, Benson Fall 2014 Miembro de Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 805
