Saltar al contenido principal
Alldaymall A88X Speaker Replacement
Qué necesitas
  1. Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: paso 1, imagen 1 de 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: paso 1, imagen 2 de 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: paso 1, imagen 3 de 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Speaker Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Speaker Replacement, Speaker: paso 3, imagen 1 de 3 Alldaymall A88X Speaker Replacement, Speaker: paso 3, imagen 2 de 3 Alldaymall A88X Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Speaker Replacement: paso 4, imagen 1 de 3 Alldaymall A88X Speaker Replacement: paso 4, imagen 2 de 3 Alldaymall A88X Speaker Replacement: paso 4, imagen 3 de 3
    Comprar
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Speaker Replacement: paso 5, imagen 1 de 3 Alldaymall A88X Speaker Replacement: paso 5, imagen 2 de 3 Alldaymall A88X Speaker Replacement: paso 5, imagen 3 de 3
    • Desolder the speaker wires from the motherboard.
Conclusión
Drhaber
Miembro Desde 02/10/16
985 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 4-1, Lacy Spring 2016 Miembro de USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 230
