Introducción
PREREQUISITE
Qué necesitas
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
Gently pry the brackets holding the touch sensor to the LCD Screen
Una persona más ha completado esta guía.
