Saltar al contenido principal
Alldaymall A88X Camera Replacement
Qué necesitas
  1. Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: paso 1, imagen 1 de 3 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: paso 1, imagen 2 de 3 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: paso 1, imagen 3 de 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Camera Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Camera Replacement, Speaker: paso 3, imagen 1 de 3 Alldaymall A88X Camera Replacement, Speaker: paso 3, imagen 2 de 3 Alldaymall A88X Camera Replacement, Speaker: paso 3, imagen 3 de 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Camera Replacement: paso 4, imagen 1 de 3 Alldaymall A88X Camera Replacement: paso 4, imagen 2 de 3 Alldaymall A88X Camera Replacement: paso 4, imagen 3 de 3
    Comprar
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Camera Replacement: paso 5, imagen 1 de 3 Alldaymall A88X Camera Replacement: paso 5, imagen 2 de 3 Alldaymall A88X Camera Replacement: paso 5, imagen 3 de 3
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X Camera Replacement, Camera: paso 6, imagen 1 de 3 Alldaymall A88X Camera Replacement, Camera: paso 6, imagen 2 de 3 Alldaymall A88X Camera Replacement, Camera: paso 6, imagen 3 de 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X Camera Replacement: paso 7, imagen 1 de 2 Alldaymall A88X Camera Replacement: paso 7, imagen 2 de 2
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X Camera Replacement: paso 8, imagen 1 de 2 Alldaymall A88X Camera Replacement: paso 8, imagen 2 de 2
    Comprar
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X Camera Replacement: paso 9, imagen 1 de 3 Alldaymall A88X Camera Replacement: paso 9, imagen 2 de 3 Alldaymall A88X Camera Replacement: paso 9, imagen 3 de 3
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X Camera Replacement: paso 10, imagen 1 de 1
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X Camera Replacement: paso 11, imagen 1 de 1
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X Camera Replacement: paso 12, imagen 1 de 2 Alldaymall A88X Camera Replacement: paso 12, imagen 2 de 2
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
Conclusión
Drhaber
Miembro Desde 02/10/16
985 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 4-1, Lacy Spring 2016 Miembro de USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 186
