Saltar al contenido principal
Alldaymall A88X Battery Replacement
Qué necesitas
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: paso 1, imagen 1 de 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: paso 1, imagen 2 de 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: paso 1, imagen 3 de 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: paso 3, imagen 1 de 3 Alldaymall A88X Battery Replacement, Battery: paso 3, imagen 2 de 3 Alldaymall A88X Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: paso 4, imagen 1 de 3 Alldaymall A88X Battery Replacement: paso 4, imagen 2 de 3 Alldaymall A88X Battery Replacement: paso 4, imagen 3 de 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: paso 5, imagen 1 de 2 Alldaymall A88X Battery Replacement: paso 5, imagen 2 de 2
    • Desolder the wires that connect the battery to the motherboard.
Conclusión
4 personas más completaron esta guía.
Alex
Miembro Desde 02/10/16
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 4-1, Lacy Spring 2016 Miembro de USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,121
