Saltar al contenido principal
Alienware m15 R6 SSD slot two Replacement
Qué necesitas
  1. Alienware m15 R6 SSD slot two Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 SSD slot two Replacement: paso 2, imagen 1 de 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 SSD slot two Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: paso 4, imagen 1 de 2 Alienware m15 R6 SSD slot two Replacement, Removing the solid-state drive in SSD slot two: paso 4, imagen 2 de 2
    • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
    • Lift the thermal shield off the solid-state drive.
    • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
  5. Alienware m15 R6 SSD slot two Replacement, Procedure to move the screw mount in SSD slot two: paso 5, imagen 1 de 1
    • Slide to remove the screw mount from the palm-rest and keyboard assembly.
    • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
Conclusión
Una persona más ha completado esta guía.
Andrzej
Miembro Desde 02/17/23
1,702 Reputación
18 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 488
