Saltar al contenido principal
Alienware X51 Motherboard Replacement
Qué necesitas
  1. Alienware X51 Motherboard Replacement, Front Panel: paso 1, imagen 1 de 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Motherboard Replacement: paso 2, imagen 1 de 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Motherboard Replacement, Fan: paso 3, imagen 1 de 2 Alienware X51 Motherboard Replacement, Fan: paso 3, imagen 2 de 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Motherboard Replacement: paso 4, imagen 1 de 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Motherboard Replacement: paso 5, imagen 1 de 3 Alienware X51 Motherboard Replacement: paso 5, imagen 2 de 3 Alienware X51 Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Motherboard Replacement, Disc Drive: paso 6, imagen 1 de 2 Alienware X51 Motherboard Replacement, Disc Drive: paso 6, imagen 2 de 2
    • Disconnect the optical-drive data and power cable.
  7. Alienware X51 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
  8. Alienware X51 Motherboard Replacement, RAM: paso 8, imagen 1 de 3 Alienware X51 Motherboard Replacement, RAM: paso 8, imagen 2 de 3 Alienware X51 Motherboard Replacement, RAM: paso 8, imagen 3 de 3
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
  9. Alienware X51 Motherboard Replacement, Heatsink: paso 9, imagen 1 de 3 Alienware X51 Motherboard Replacement, Heatsink: paso 9, imagen 2 de 3 Alienware X51 Motherboard Replacement, Heatsink: paso 9, imagen 3 de 3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
  10. Alienware X51 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 Alienware X51 Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Remove the single 1.0 mm screw with a Phillips #1 screwdriver.
    • Firmly remove the internal PC system by lifting it out of the PC.
  11. Alienware X51 Motherboard Replacement: paso 11, imagen 1 de 2 Alienware X51 Motherboard Replacement: paso 11, imagen 2 de 2
    • Loosen the four 1.0 mm screws holding down the motherboard using a Phillips #1 screwdriver.
  12. Alienware X51 Motherboard Replacement: paso 12, imagen 1 de 2 Alienware X51 Motherboard Replacement: paso 12, imagen 2 de 2
    • Disconnect the two SATA plugs going into the motherboard processor.
  13. Alienware X51 Motherboard Replacement: paso 13, imagen 1 de 1
    • Disconnect the rectangular power supply plug from the motherboard into the other circuit board.
  14. Alienware X51 Motherboard Replacement: paso 14, imagen 1 de 1
    • Disconnect the bundled cable connector going into the motherboard.
  15. Alienware X51 Motherboard Replacement: paso 15, imagen 1 de 1
    • Disconnect the white bundled cable connector from the motherboard.
  16. Alienware X51 Motherboard Replacement: paso 16, imagen 1 de 1
    • Disconnect the rectangular yellow bundled cable connector plug going into the motherboard.
  17. Alienware X51 Motherboard Replacement: paso 17, imagen 1 de 1
    • Disconnect the power supply.
  18. Alienware X51 Motherboard Replacement: paso 18, imagen 1 de 1
    • Disconnect the rectangular white bundled cable connector going into the motherboard.
  19. Alienware X51 Motherboard Replacement: paso 19, imagen 1 de 2 Alienware X51 Motherboard Replacement: paso 19, imagen 2 de 2
    • Gently slide and lift out the motherboard from the PC.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 25
Todo El Tiempo: 371
