Saltar al contenido principal
Alienware X51 Heatsink Replacement
Qué necesitas
  1. Alienware X51 Heatsink Replacement, Front Panel: paso 1, imagen 1 de 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Heatsink Replacement: paso 2, imagen 1 de 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Heatsink Replacement, Fan: paso 3, imagen 1 de 2 Alienware X51 Heatsink Replacement, Fan: paso 3, imagen 2 de 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Heatsink Replacement: paso 4, imagen 1 de 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Heatsink Replacement: paso 5, imagen 1 de 3 Alienware X51 Heatsink Replacement: paso 5, imagen 2 de 3 Alienware X51 Heatsink Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Heatsink Replacement, Heatsink: paso 6, imagen 1 de 3 Alienware X51 Heatsink Replacement, Heatsink: paso 6, imagen 2 de 3 Alienware X51 Heatsink Replacement, Heatsink: paso 6, imagen 3 de 3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
Conclusión
alondra
Miembro Desde 10/02/23
123 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 134
