Saltar al contenido principal
Alienware X51 Disc Drive Replacement
Qué necesitas
  1. Alienware X51 Disc Drive Replacement, Front Panel: paso 1, imagen 1 de 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Disc Drive Replacement: paso 2, imagen 1 de 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Disc Drive Replacement, Disc Drive: paso 3, imagen 1 de 2 Alienware X51 Disc Drive Replacement, Disc Drive: paso 3, imagen 2 de 2
    • Disconnect the optical-drive data and power cable.
  4. Alienware X51 Disc Drive Replacement: paso 4, imagen 1 de 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 50
Ultimos 30 días: 101
Todo El Tiempo: 308
