Saltar al contenido principal
Alienware P18G M14X R1 RAM Replacement
Qué necesitas
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: paso 1, imagen 1 de 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 RAM Replacement: paso 2, imagen 1 de 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 RAM Replacement: paso 3, imagen 1 de 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew the two 6.35 mm using the PH1 screw driver.
  5. Alienware P18G M14X R1 RAM Replacement: paso 5, imagen 1 de 2 Alienware P18G M14X R1 RAM Replacement: paso 5, imagen 2 de 2
    • Lift the plate and remove it to uncover the RAM sticks.
  6. Alienware P18G M14X R1 RAM Replacement: paso 6, imagen 1 de 1
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
  7. Alienware P18G M14X R1 RAM Replacement: paso 7, imagen 1 de 1
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
  8. Alienware P18G M14X R1 RAM Replacement: paso 8, imagen 1 de 1
  9. Alienware P18G M14X R1 RAM Replacement: paso 9, imagen 1 de 1
    • Pull the second ram stick out of its housing.
Conclusión
Andonaq Grozdani
Miembro Desde 03/01/18
892 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 1,039
