Introducción
This guide will show you how to replace a broken optical drive. First you will need to remove the back cover then the battery in-order to get to the optical drive.
Qué necesitas
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Casi Terminas!
Conclusión
