Saltar al contenido principal
Alienware P18G M14X R1 Battery Replacement
Qué necesitas
  1. Alienware P18G M14X R1 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Battery Replacement: paso 2, imagen 1 de 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Battery Replacement: paso 3, imagen 1 de 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Battery Replacement: paso 5, imagen 1 de 2 Alienware P18G M14X R1 Battery Replacement: paso 5, imagen 2 de 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Battery Replacement: paso 6, imagen 1 de 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
Conclusión
2 personas más completaron esta guía.
Andonaq Grozdani
Miembro Desde 03/01/18
892 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 1,991
