Saltar al contenido principal
Alienware M17x RAM Replacement
Qué necesitas
  1. Alienware M17x RAM Replacement, Battery: paso 1, imagen 1 de 2 Alienware M17x RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x RAM Replacement: paso 2, imagen 1 de 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x RAM Replacement: paso 3, imagen 1 de 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x RAM Replacement: paso 4, imagen 1 de 2 Alienware M17x RAM Replacement: paso 4, imagen 2 de 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x RAM Replacement, RAM: paso 5, imagen 1 de 2 Alienware M17x RAM Replacement, RAM: paso 5, imagen 2 de 2
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
  6. Alienware M17x RAM Replacement: paso 6, imagen 1 de 2 Alienware M17x RAM Replacement: paso 6, imagen 2 de 2
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
  7. Alienware M17x RAM Replacement: paso 7, imagen 1 de 1
    • Remove the bottom RAM card in a similar manner.
Conclusión
Una persona más ha completado esta guía.
Un comentario
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 476
