Saltar al contenido principal
Alienware M17x P01E RAM Replacement
Qué necesitas
  1. Alienware M17x P01E RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E RAM Replacement: paso 2, imagen 1 de 2 Alienware M17x P01E RAM Replacement: paso 2, imagen 2 de 2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E RAM Replacement, Compartment Door: paso 3, imagen 1 de 1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E RAM Replacement: paso 4, imagen 1 de 2 Alienware M17x P01E RAM Replacement: paso 4, imagen 2 de 2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E RAM Replacement, RAM: paso 5, imagen 1 de 2 Alienware M17x P01E RAM Replacement, RAM: paso 5, imagen 2 de 2
    • Remove the Phillips #1 screw holding the plate.
    • Use your hand to remove the plate.
    • The screw is held to the plate by a washer and cannot be removed.
  6. Alienware M17x P01E RAM Replacement: paso 6, imagen 1 de 2 Alienware M17x P01E RAM Replacement: paso 6, imagen 2 de 2
    • Pull the clips to the side away from each other. The RAM will pop up.
    • Lift forward and gently loosen to pull out of socket.
  7. Alienware M17x P01E RAM Replacement: paso 7, imagen 1 de 1
    • For the second RAM card use the opening tool to gently lift the RAM card forward.
Conclusión
2 personas más completaron esta guía.
Jose
Miembro Desde 09/19/18
324 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 690
